Activation lost?
I have the kit and it worked for a few weeks. Today, I tried using it and it’s asking me to activate it. I don’t have the activation key with me but I thought the license is tied to the gimbal, why is it asking me to activate?
I tried rebooting, removing app and reinstalling — both Testflight and prod. Still getting that prompt.
If you have the TestFlight version, you can select the upgrade option without being charged.
Both versions gave me the same problem. I reverted back to prod version. It prompted me to Activate multiple times, even after having gone through Activation sucessfully. Here’s the logs:
I believe this is where it prompted me to activate, which I did.
FoloCam v1.5 build 4
[814320951.729] Detector: Pixel transfer session created successfully
[814320951.729] Detector: Buffer pools created successfully
[814320951.731] Generated new verification ID: 0000000339583911
[814320951.731] Peer ID: iPhone6862 (hash of verification ID)
[814320951.733] RTMPStreamer initialized
[814320951.736] H.264 compression session using bitrate: 5.0 Mbps (5000000 bps)
[814320951.738] H.264 compression session created successfully
[814320951.738] Audio converter will be initialized on first audio frame
[814320951.738] Pixel transfer session created successfully
[814320951.738] Resized buffer pool created successfully (1920x1080)
[814320951.738] No saved tracking mode, defaulting to Basketball
[814320951.738] No saved zoom level, defaulting to 1x
[814320951.739] TrackingCoordinator: Initializing with Basketball mode and 1.0x zoom...
[814320951.765] Dual camera available: true
[814320951.765] DockManager: Sport mode set to basketball
[814320951.765] DockManager: Starting monitoring...
[814320951.765] inf: 0.0ms mem: 17M cpu: 34% bat: 40% thm: fair
[814320951.772] DockManager: Received state change: Undocked
[814320951.784] Started advertising as: iPhone6862
[814320951.818] VolumeButtonHandler: MPVolumeView created
[814320951.818] Preview layer not available in makeUIView
[814320951.822] VolumeButtonHandler: ===== ACTIVATING VOLUME BUTTON HANDLING =====
[814320951.822] VolumeButtonHandler: Current system volume: 0.5
[814320951.822] VolumeButtonHandler: Volume observer registered
[814320951.822] VolumeButtonHandler: ===== ACTIVATION COMPLETE =====
[814320951.926] VolumeButtonHandler: Set volume to 0.5 for button detection
[814320952.117] SubscriptionManager: Premium = false (none)
[814320952.297] DockManager: Toggling system tracking to force state update...
[814320952.361] SubscriptionManager: Loaded product: Premium Yearly - $69.99
[814320955.694] Model 'folocam_basketball_s4' loaded successfully
[814320955.694] TrackingCoordinator: Basketball mode initialized (model loaded)
[814320955.696] TrackingCoordinator: Starting camera (model already loaded: Basketball)...
[814320955.696] Starting camera capture session...
[814320955.697] Camera session running: true
[814320955.697] Zoom will be applied when camera starts: 1.0
[814320959.855] Using camera: Back Camera, type: AVCaptureDeviceTypeBuiltInWideAngleCamera
[814320959.855] Active format dimensions: 3840 x 2160 @ 30fps
[814320959.855] Zoom range: 1.0 - 129.125
[814320959.856] Field of view: 74.59712 degrees
[814320959.882] Audio input added successfully
[814320959.882] Audio output added successfully
[814320960.139] Camera session configured successfully
[814320960.142] Camera permission granted - restarting dock monitoring
[814320960.142] DockManager: Starting monitoring...
[814320960.144] Camera session already configured, skipping
[814320960.157] DockManager: Received state change: Docked
[814320960.157] Gimbal: ShenzhenJXROBOTTechnologyCoLtd Motorized Stand 1.0.63
[814320960.159] start monitoring gimbal states
[814320960.306] VolumeButtonHandler: Volume changed to 1.0 (from 0.5)
[814320960.306] VolumeButtonHandler: ★★★ VOLUME UP DETECTED ★★★
[814320960.306] VolumeButtonHandler: Volume changed to 0.5 (from 0.5)
[814320960.309] Starting camera capture session...
[814320960.309] Camera session running: true
[814320960.310] Preview layer added in updateUIView
[814320960.310] CameraView: Volume button pressed - starting recording
[814320960.310] Recording at 4K @ 30fps
[814320960.320] Audio writer input added successfully
[814320960.321] Created SRT file at: /var/mobile/Containers/Data/Application/C6B64AF8-5E3E-4E1C-AD90-0C1A48F12552/Documents/basketball-20261021-201600.srt
[814320960.348] Started recording to: /var/mobile/Containers/Data/Application/C6B64AF8-5E3E-4E1C-AD90-0C1A48F12552/Documents/basketball-20261021-201600.mov
[814320960.350] Zoom: 1.0x | Device zoom: 1.0x | FOV: 74.59712°
[814320960.350] VolumeButtonHandler: Reset volume to 0.5
[814320960.364] Recording session started with audio at time: 4228.687520833333
[814320960.673] DockManager: Toggling system tracking to force state update...
[814320960.787] Metal logo texture created from image: 480x120 at (x: 3320, y: 2000)
[814320961.844] inf: 37.1ms mem: 621M cpu: 73% bat: 40% thm: nominal
[814320962.566] BLE: Found gimbal: COMITOK MOGO (id: 8B4BF9AC-5482-8026-FC54-3C476673A8E6)
[814320962.568] BLE: Connected to COMITOK MOGO, discovering UART service...
[814320962.570] BLE: Found TX characteristic
[814320962.570] BLE: Subscribed to notifications
[814320962.612] BLE: Notifications enabled
[814320962.993] Starting camera capture session...
[814320962.993] Camera session running: true
[814320962.993] Zoom: 1.0x | Device zoom: 1.0x | FOV: 74.59712°
[814320965.828] Recording stopped: 153 frames written at 28.00fps, 0 frames dropped due to backpressure
This shows I have a valid license (not sure if it should show expiry since I have the kit):
[814320979.739] Live reconfigure: Back Dual Camera 4K @ 30fps
[814320980.539] Live reconfigure: Back Dual Camera 4K @ 30fps
[814320980.801] Model 'folocam_soccer_pro_s3' loaded successfully
[814320981.255] Live reconfigure: Back Dual Camera 4K @ 30fps
[814320981.844] inf: 35.7ms mem: 873M cpu: 78% bat: 40% thm: nominal
[814320982.506] Live reconfigure: Back Dual Camera 4K @ 30fps
[814320990.970] Pitch: -1.8° [-21.8° - 18.2°], height: 7ft, 2.0x)
[814320991.010] Pitch: -2.1° [-22.1° - 17.9°], height: 8ft, 2.0x)
[814320991.120] Pitch: -2.6° [-22.6° - 17.4°], height: 10ft, 2.0x)
[814320991.410] Pitch: -2.8° [-22.8° - 17.2°], height: 11ft, 2.0x)
[814320991.844] inf: 37.7ms mem: 697M cpu: 97% bat: 40% thm: fair
[814320991.868] Pitch: -3.3° [-23.3° - 16.7°], height: 13ft, 2.0x)
[814320994.640] Live reconfigure: Back Dual Camera 4K @ 30fps
[814320995.391] Live reconfigure: Back Dual Camera 4K @ 30fps
[814320995.976] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321001.843] inf: 37.8ms mem: 696M cpu: 76% bat: 40% thm: fair
[814321011.843] inf: 37.9ms mem: 698M cpu: 77% bat: 40% thm: fair
[814321020.636] Camera: Session interrupted - video device not available in background
[814321119.954] inf: 41.9ms mem: 606M cpu: 0% bat: 40% thm: fair
[814321120.161] Camera: Session interruption ended - resuming
[814321120.237] Starting camera capture session...
[814321120.237] Camera session running: true
[814321120.240] Zoom: 1.9778204770427046x | Device zoom: 1.9778205156326294x | FOV: 37.71683°
[814321121.844] inf: 44.0ms mem: 762M cpu: 73% bat: 40% thm: nominal
[814321130.588] SubscriptionManager: Premium = true (gimbal license)
[814321130.588] LicenseManager: license active, expires 2027-10-22
[814321131.844] inf: 38.2ms mem: 757M cpu: 76% bat: 40% thm: nominal
[814321141.844] inf: 40.3ms mem: 756M cpu: 70% bat: 40% thm: nominal
[814321147.895] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321148.596] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321151.844] inf: 38.4ms mem: 760M cpu: 100% bat: 40% thm: fair
[814321156.779] Recording at 4K @ 30fps
[814321156.784] Audio writer input added successfully
[814321156.785] Created SRT file at: /var/mobile/Containers/Data/Application/C6B64AF8-5E3E-4E1C-AD90-0C1A48F12552/Documents/soccer-pro-20261021-201916.srt
[814321156.791] Started recording to: /var/mobile/Containers/Data/Application/C6B64AF8-5E3E-4E1C-AD90-0C1A48F12552/Documents/soccer-pro-20261021-201916.mov
[814321156.792] Recording session started with video at time: 4425.11425522
[814321156.803] Metal logo texture created from image: 480x120 at (x: 3320, y: 2000)
[814321161.844] inf: 41.0ms mem: 715M cpu: 74% bat: 40% thm: fair
[814321163.713] Recording stopped: 208 frames written at 30.06fps, 0 frames dropped due to backpressure
Then in prompts me to Activate again.
[814321783.693] Detector: Pixel transfer session created successfully
[814321783.693] Detector: Buffer pools created successfully
[814321783.696] Loaded verification ID: 0000000339583911
[814321783.696] Peer ID: iPhone6862 (hash of verification ID)
[814321783.697] RTMPStreamer initialized
[814321783.705] H.264 compression session using bitrate: 5.0 Mbps (5000000 bps)
[814321783.706] H.264 compression session created successfully
[814321783.706] Audio converter will be initialized on first audio frame
[814321783.706] Pixel transfer session created successfully
[814321783.706] Resized buffer pool created successfully (1920x1080)
[814321783.707] Loaded saved tracking mode: Soccer Pro
[814321783.707] Loaded saved zoom level: 2.0x
[814321783.707] Pitch: -14.8° [-34.8° - 5.2°], height: 13ft, 1.0x)
[814321783.707] TrackingCoordinator: Initializing with Soccer Pro mode and 2.0x zoom...
[814321783.707] Pitch: -3.3° [-23.3° - 16.7°], height: 13ft, 2.0x)
[814321783.733] Dual camera available: true
[814321783.733] DockManager: Sport mode set to soccerPro
[814321783.733] DockManager: Starting monitoring...
[814321783.733] inf: 0.0ms mem: 17M cpu: 35% bat: 35% thm: nominal
[814321783.742] Started advertising as: iPhone6862
[814321783.773] VolumeButtonHandler: MPVolumeView created
[814321783.774] Preview layer not available in makeUIView
[814321783.777] VolumeButtonHandler: ===== ACTIVATING VOLUME BUTTON HANDLING =====
[814321783.777] VolumeButtonHandler: Current system volume: 1.0
[814321783.777] VolumeButtonHandler: Volume observer registered
[814321783.777] VolumeButtonHandler: ===== ACTIVATION COMPLETE =====
[814321783.816] Using camera: Back Dual Camera, type: AVCaptureDeviceTypeBuiltInDualCamera
[814321783.816] Active format dimensions: 3840 x 2160 @ 30fps
[814321783.816] Zoom range: 1.0 - 129.125
[814321783.816] Field of view: 74.59712 degrees
[814321783.833] Audio input added successfully
[814321783.833] Audio output added successfully
[814321783.834] Camera session configured successfully
[814321783.836] Camera permission granted - restarting dock monitoring
[814321783.836] DockManager: Starting monitoring...
[814321783.846] SubscriptionManager: Premium = false (none)
[814321783.846] Preview layer added in updateUIView
[814321783.868] SubscriptionManager: Loaded product: Premium Yearly - $69.99
[814321783.879] VolumeButtonHandler: Set volume to 0.5 for button detection
[814321784.365] DockManager: Toggling system tracking to force state update...
[814321784.735] Model 'folocam_soccer_pro_s3' loaded successfully
[814321784.735] TrackingCoordinator: Soccer Pro mode initialized (model loaded)
[814321784.738] TrackingCoordinator: Starting camera (model already loaded: Soccer Pro)...
[814321784.738] Starting camera capture session...
[814321784.917] Camera session running: true
[814321784.917] Zoom: 2.0x | Device zoom: 2.0x | FOV: 37.29856°
[814321786.400] DockManager: Received state change: Docked
[814321786.403] Gimbal: ShenzhenJXROBOTTechnologyCoLtd Motorized Stand 1.0.63
[814321786.405] start monitoring gimbal states
[814321786.419] BLE: Found gimbal: COMITOK MOGO (id: 109651BC-A27F-C140-FB9F-6F150060A91A)
[814321786.419] BLE: Connected to COMITOK MOGO, discovering UART service...
[814321786.498] BLE: Found TX characteristic
[814321786.499] BLE: Subscribed to notifications
[814321786.675] BLE: Notifications enabled
[814321790.499] BLE: Sending STATUS request: 55 07 60 04 b2 d3 8f
[814321790.548] BLE: Gimbal serial: 05020000, product: BLE2, version: 0001
[814321790.557] SubscriptionManager: Premium = true (gimbal license)
[814321793.801] inf: 35.8ms mem: 625M cpu: 72% bat: 35% thm: nominal
[814321794.614] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321795.397] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321803.801] inf: 38.5ms mem: 625M cpu: 76% bat: 35% thm: nominal
[814321804.932] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321805.499] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321806.166] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321810.016] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321811.682] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321812.215] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321813.801] inf: 37.3ms mem: 625M cpu: 80% bat: 35% thm: nominal
[814321814.267] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321814.934] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321816.384] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321817.017] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321817.501] Live reconfigure: Back Dual Camera 4K @ 30fps
[814321823.801] inf: 35.9ms mem: 627M cpu: 78% bat: 35% thm: fair
[814321833.801] inf: 37.2ms mem: 625M cpu: 78% bat: 35% thm: fair
[814321843.801] inf: 37.7ms mem: 625M cpu: 72% bat: 35% thm: fair
[814321853.800] inf: 39.3ms mem: 625M cpu: 76% bat: 35% thm: fair
[814321854.550] Recording at 4K @ 30fps
[814321854.565] Audio writer input added successfully
[814321854.566] Created SRT file at: /var/mobile/Containers/Data/Application/C6B64AF8-5E3E-4E1C-AD90-0C1A48F12552/Documents/soccer-pro-20261021-203054.srt
[814321854.587] Started recording to: /var/mobile/Containers/Data/Application/C6B64AF8-5E3E-4E1C-AD90-0C1A48F12552/Documents/soccer-pro-20261021-203054.mov
[814321854.600] Recording session started with audio at time: 5043.2299375
[814321863.801] inf: 38.9ms mem: 637M cpu: 80% bat: 35% thm: fair
[814321865.620] Recording stopped: 331 frames written at 30.04fps, 0 frames dropped due to backpressure
I’ve gone back to Testflight version and it’s working again; has not asked me to Activate. I’ll store the activation key electronically in case this happens again.
Here’s the log from Testflight version. It does say no Premium subscription and then it finds it. I guess that’s normal. It did not prompt me to Activate. It also doesn’t show an expiry date.
FoloCam v1.6 build 6
[814325390.364] Detector: Pixel transfer session created successfully
[814325390.364] Detector: Buffer pools created successfully
[814325390.365] Loaded verification ID: 0000000339583911
[814325390.365] Peer ID: iPhone6862 (hash of verification ID)
[814325390.365] RTMPStreamer initialized
[814325390.368] H.264 compression session using bitrate: 5.0 Mbps (5000000 bps)
[814325390.371] H.264 compression session created successfully
[814325390.371] Audio converter will be initialized on first audio frame
[814325390.371] Pixel transfer session created successfully
[814325390.371] Resized buffer pool created successfully (1920x1080)
[814325390.371] Loaded saved tracking mode: Soccer Pro
[814325390.371] Loaded saved zoom level: 2.0x
[814325390.371] Pitch: -14.8° [-34.8° - 5.2°], height: 13ft, 1.0x)
[814325390.372] TrackingCoordinator: Initializing with Soccer Pro mode and 2.0x zoom...
[814325390.372] Pitch: -3.3° [-23.3° - 16.7°], height: 13ft, 2.0x)
[814325390.394] Dual camera available: true
[814325390.394] DockManager: Sport mode set to soccerPro
[814325390.394] DockManager: Starting monitoring...
[814325390.394] O2: Tracker disabled
[814325390.395] inf: 0.0ms mem: 17M cpu: 22% bat: 40% thm: fair
[814325390.403] Started advertising as: iPhone6862
[814325390.426] VolumeButtonHandler: MPVolumeView created
[814325390.427] Preview layer not available in makeUIView
[814325390.429] VolumeButtonHandler: ===== ACTIVATING VOLUME BUTTON HANDLING =====
[814325390.454] VolumeButtonHandler: Current system volume: 0.5
[814325390.455] VolumeButtonHandler: Volume observer registered
[814325390.455] VolumeButtonHandler: ===== ACTIVATION COMPLETE =====
[814325390.559] VolumeButtonHandler: Set volume to 0.5 for button detection
[814325390.635] Using camera: Back Dual Camera, type: AVCaptureDeviceTypeBuiltInDualCamera
[814325390.635] Active format dimensions: 3840 x 2160 @ 30fps
[814325390.635] Zoom range: 1.0 - 129.125
[814325390.635] Field of view: 74.59712 degrees
[814325390.643] Audio input added successfully
[814325390.643] Audio output added successfully
[814325390.643] Camera session configured successfully
[814325390.644] Camera permission granted - restarting dock monitoring
[814325390.644] DockManager: Starting monitoring...
[814325390.647] Preview layer added in updateUIView
[814325391.053] SubscriptionManager: Premium = false (none)
[814325391.172] DockManager: Toggling system tracking to force state update...
[814325391.538] SubscriptionManager: Loaded product: Premium Yearly - $69.99
[814325396.311] Model 'folocam_soccer_pro_s3' loaded successfully
[814325396.311] TrackingCoordinator: Soccer Pro mode initialized (model loaded)
[814325396.313] TrackingCoordinator: Starting camera (model already loaded: Soccer Pro)...
[814325396.313] Starting camera capture session...
[814325396.590] Camera session running: true
[814325396.590] Zoom: 2.0x | Device zoom: 2.0x | FOV: 37.29856°
[814325400.402] Detector timing (ms, avg of 37): scale 10.9 crop 1.3 align 6.1 concat 1.1 predict 82.7 parse 0.0 total 102.1
[814325400.471] inf: 33.0ms mem: 568M cpu: 71% bat: 40% thm: fair
[814325401.577] Live reconfigure: Back Dual Camera 4K @ 30fps
[814325402.295] Live reconfigure: Back Dual Camera 4K @ 30fps
[814325410.405] Detector timing (ms, avg of 91): scale 10.6 crop 1.3 align 7.8 concat 1.0 predict 89.1 parse 0.0 total 109.9
[814325410.472] inf: 36.6ms mem: 569M cpu: 67% bat: 40% thm: fair
[814325420.410] Detector timing (ms, avg of 91): scale 10.8 crop 1.3 align 7.8 concat 0.9 predict 89.0 parse 0.0 total 109.9
[814325420.472] inf: 36.7ms mem: 572M cpu: 70% bat: 40% thm: fair
[814325430.462] Detector timing (ms, avg of 93): scale 10.6 crop 1.3 align 7.4 concat 0.9 predict 87.7 parse 0.0 total 108.0
[814325430.472] inf: 36.0ms mem: 572M cpu: 71% bat: 40% thm: fair
[814325439.330] DockManager: Received state change: connected(FoloCam.GimbalDeviceInfo(identifier: C83323BE-CDC0-40D3-8DF7-23167CACE263, name: "ShenzhenJXROBOTTechnologyCoLtd", hardwareModel: "Motorized Stand", firmwareVersion: "1.0.63"))
[814325439.331] Gimbal: ShenzhenJXROBOTTechnologyCoLtd Motorized Stand 1.0.63
[814325439.335] start monitoring gimbal states
[814325439.348] BLE: Found gimbal: COMITOK MOGO (id: F93F1058-02A4-F5C1-0BDE-A9F335E96F6B)
[814325439.349] BLE: Connected to COMITOK MOGO, discovering UART service...
[814325439.432] BLE: Found TX characteristic
[814325439.432] BLE: Subscribed to notifications
[814325439.607] BLE: Notifications enabled
[814325440.471] inf: 36.9ms mem: 572M cpu: 74% bat: 40% thm: fair
[814325440.552] Detector timing (ms, avg of 91): scale 10.8 crop 1.4 align 7.5 concat 0.9 predict 90.1 parse 0.0 total 110.8
[814325443.434] BLE: Sending STATUS request: 55 07 60 04 b2 d3 8f
[814325443.478] BLE: Gimbal serial: 05020000, product: BLE2, version: 0001
[814325443.490] SubscriptionManager: Premium = true (gimbal license)
[814325447.714] Live reconfigure: Back Dual Camera 4K @ 30fps
[814325448.432] Live reconfigure: Back Dual Camera 4K @ 30fps
[814325449.265] Live reconfigure: Back Dual Camera 4K @ 30fps
[814325450.472] inf: 40.7ms mem: 574M cpu: 74% bat: 40% thm: serious
[814325450.573] Detector timing (ms, avg of 82): scale 12.3 crop 1.3 align 8.8 concat 1.1 predict 98.6 parse 0.1 total 122.2
[814325460.472] inf: 40.0ms mem: 570M cpu: 71% bat: 40% thm: serious
[814325460.654] Detector timing (ms, avg of 84): scale 11.5 crop 1.3 align 8.8 concat 1.0 predict 97.1 parse 0.0 total 119.9
[814325470.472] inf: 40.0ms mem: 570M cpu: 68% bat: 40% thm: serious
[814325470.755] Detector timing (ms, avg of 84): scale 11.6 crop 1.3 align 9.0 concat 1.1 predict 97.1 parse 0.1 total 120.2
[814325480.472] inf: 40.0ms mem: 570M cpu: 69% bat: 40% thm: serious
[814325480.756] Detector timing (ms, avg of 83): scale 11.9 crop 1.3 align 8.6 concat 1.1 predict 97.4 parse 0.1 total 120.4
[814325484.505] Camera: Session interrupted - video device not available in background
[814325509.409] inf: 43.1ms mem: 423M cpu: 0% bat: 40% thm: serious
[814325509.632] Camera: Session interruption ended - resuming
[814325509.663] Starting camera capture session...
[814325509.663] Camera session running: true
[814325509.664] Zoom: 2.0x | Device zoom: 2.0x | FOV: 37.29856°
[814325509.858] Detector timing (ms, avg of 30): scale 11.3 crop 1.2 align 9.2 concat 1.0 predict 109.0 parse 0.1 total 131.8
[814325510.472] inf: 45.0ms mem: 573M cpu: 64% bat: 40% thm: serious
[814325511.672] Set actual zoom to 1.99
[814325511.705] Set actual zoom to 1.98
[814325511.739] Set actual zoom to 1.97
Yes it reverted back to trial mode but ok after “repurchasing” again.
