My son’s soccer team uses the TeamSnap One app for communication: texting, calendar, etc.
A new feature in the app that we are using is livestreaming. Until now, we’ve just had a parent use their phone to film the game. Often that parent was me.
I bought the FoloCam kit on Amazon (lifetime FoloCam subscription + COMITOK Mogo)I used it to record and livestream the second half of his game today. It works pretty well!
My only problem is the iPhone battery was almost drained. It’s an old iPhone 14Pro. The battery life is probably a bit degraded.
To record an entire soccer game, I see 3 options:
Swap phones at halftime
Use a newer phone that has enough battery life
Connect a battery charger to the iPhone while it is in use… is that possible while on the COMITOK mogo gimble?
Has anyone else had this battery drain problem? What was your solution?
I’m using a Powerbank to charge the phone during the match. Make sure that the charging cable is fixed and doesn’t put any tension on the gimble. Otherwise the Gimble might wear out quickly.
I use cable ties to put the power bank + charging cable in place.
To deal with the heat and battery issue I turn on flight mode. You will still need to leave Bluetooth and wifi on. I am not entirely sure why but if I recalled correctly wifi off makes the connection to the gimbal abit funky as well
Only issue I am facing now is that the secondary IPad that I use for control doesn’t connect very well either. I think it’s a user error issue.
Maybe @gchen can help with clarifying what’s the minimum requirement of things that needs to be turned on for remote control to work.
