These videos were definitely more of a challenge as the 3v3 shift changes on the fly definitely got the attention of the camera rather than staying focussed on the play.
The Shootout was strange as it was tracking the shooter and decided right when they were about to shoot… to take the focus off and maybe look a the referee? Some were ok, but the last minute pan away from the action was weird.
Good fast action and glad to see the camera keeping up.
With less data points moving on the screen it is probably gets more difficult to determine where the focus should be?
Being lower at ice level and closer to the rink also reduces the amount of players within the vision range at any given time i think.
Do you think locating the camera higher up with a sharper angle looking down would have helped?
For assisting coaches to help review game situations I am leaning towards more distance to include as many players as possible which can better help analyze how the play developed and where mistakes were made.
But if looking just for highlights then closer up is nicer for sure.
I might try a higher position. The problem with that rink was the timekeeper box. It had a solid roof, and if I went any higher, it would have created a blind spot on the ice so looking through the timekeepers box is better then being blocked by the roof. I had to also not be on the actual goal line and away from the timekeepers box so that the roof would not block a large portion of the neutral zone…. terrible rink…
I put this video I did today of the 3rd period manually. I did use the Insta360 Flow 2 PRO in Free Tilt mode to keep the horizon level while in a tilt and I did notice the Insta360 would sometimes slowly pan and was also delayed as I would pan, and the insta360 would absorb the initial acceleration of the movement.
Aside from the typical dad watching their kid and not focusing on the play, I would say my goal would be that FoloCam be able to get close to this result.
As mentioned before, there are just a few core challenges.
getting in front of the play and the puck rusher so that you get the goalie in view fast enough to see the full shot
only panning to the edge of the arena and no more. When in the endzone, there should only be a slight movement (in this case) to capture to 2 diagonal extremes. The bottom corner and to top blue line. Only a small shift otherwise the camera can essentially stay stable in the zones
reduce left right left right left right abrupt motions or at least dampen them as much as possible when following the puck with sudden 180 degree changes
this is a hard one… understand the game to know where to focus the camera. It’s fine when the puck is in play but as soon as it’s icing, line changes on the fly or faceoffs, the camera needs to know where to bring the focus to when the puck may NOT be in place, being picked up by a referee, etc.
After looking at your recent videos I am leaning to always recording at 60fps and 1x zoom going forward.
1.5x zoom and 30fps is just too choppy and jagged compared to your smoother videos which feel more easier on the eyes. Or are you doing some extra post processing?
When you say you did the video manually - just confirming you hand holding the gimbal instead of using a tripod?
I am with you on the 60fps and 1x zoom. When FoloCam becomes more accurate and can maintain good framing, we may be able to go to 1.5x zoom. Gilbert thinks 60fps at 1.5x might be too much for the phones processing wise.
Some of my videos are post processed. I put that in the title saying “iMovie stabilization”. So example… Sharks vs Panthers has 2 videos I uploaded. They are the same videos but one is pure FoloCam and one is post processed using iMovie. You can see that iMovie dampens the jerky left right motions and smooths them out. To do that, it crops some of the frame down the same way GoPro stabilization works but GoPro does it on the fly so there is less video degradation as there is no re-encoding of the data.
My manual filming is no FoloCam. I am using a fluid tripod and panning left and right manually to follow the plays. For the first time, I am using the Insta360 to correct an issue I have always had which is keep the horizon level when the tripod is tilted. I can show you an extreme example of that if you want. Imagine you are in a booth right above the ice on the 2nd level looking down on the ice. The tripod is sticking out the window and tilted almost 45 degrees down… which means when you pan to the endzones, the horizon is tilted at 45 degrees…
Recently with the correct settings and using the PF setting on the gimbal I have found the tracking panning is smooth enough to not require any post processing which saves alot of time.
