Switch video quality to 1080p 60fps and rotating to the other side
Hi , i run a 7 aside football matches platform in which i organize games and players who wants to play football but dont have a team to play with can join individually and enjoy the games . I came across folocam after buying insta360 flow 2 pro gimbal in order to record clips of the games without the need on actual person to handle the recording. My question is , will there be an option to decrease the quality to 1080p60 since when i share the recorded footage in 4k60 with the players on the telegram community that i share the recordings at , some older android phones are not able to play them making me go through an extra step in converting each video and compressing it so that it would be easier to download and view for everyone . Also , this would help in taking less storage space on the phone .
On another note , i had an issue with the tracking when i recorded a match for 8-aside match . My setup was a tripod with an extension neck and my insta 360 gimbal . The height that the gimbal placed at was approximately 3 meters. And i used the normal soccer mode not the pro with no zoom meaning (1x) was used . The issue was that when the ball or the action was on the other side of the pitch , the gimbal started rotating right and left and then it rotated horizontally into the other side filming the fence of the pitch. This happened several times . Idk what caused this issue to happen but my guess is that the tracker lost the ball .
I’m reluctant to reduce video quality just to save storage space or make videos easier to play on older devices. Video quality is one of FoloCam’s top design priorities, so lowering the recording resolution feels like a step backward.
Would you mind sharing a video showing this behavior? If you still have the accompanying log file, that would be very helpful too.
Hey brother, thank you for you replies . Unfortunately i have deleted the videos where the camera rotates the opposite way but i guess it’s because i located the gimbal higher than usual without changing the tripod height in the app . Because when i used a fixed height such as 2 m and kept the tripod and gimbal around the same height . The app behaved very well and the tracking was pretty good .
On another note , i noticed some recordings have not matching audio and video . Like the audio is way much ahead of the video . My guess is that the phone’s temperature rises which has an impact on the sound . Im using iphone 14 pro for tracking . Also , while recording i noticed that removing the case helps in decreasing the temperature of the phone . But whenever i try to charge my phone while recording and tracking . The gimbal loses connection. Idk if that’s related to the gimbal or the app .
Finally , if it’s possible to share a code for the premium version and add a me as a beta tester especially for soccer and soccer pro since I’m using the app to record matches on a daily basis .
Thank you so much for efforts and wish you all the best and success. @gchen
