Best setup for basketball highlight capture: FoloCam vs. dual cameras?
We tested FoloCam for basketball last night using the Basketball Pro model with an Insta360 Flow 2 Pro and iPhone 16 Pro Max.
Overall, it worked fairly well. The tracking was good, it rarely completely missed a play, and the video quality looked great. The main issue was that some of the faster pans/sudden movements were a little jerky. For example, it might be following the action correctly but then make a quick, abrupt adjustment that makes that moment harder to watch. Is smoothing this type of movement something you’re continuing to improve with the basketball models?
I’m also curious what setup you’d recommend for our particular use case. We film numerous basketball games every week, but we actually don’t need a polished full-game video. Our end product is individual highlights that we cut from the footage, crop/verticalize, and deliver to the players.
Because of that, I’ve also been looking at the two-GoPro setup recommended by ActionStitch. In our case, we wouldn’t necessarily even need to stitch the two angles together. We could potentially have one fixed camera covering each side of the court and pull highlights from whichever camera captured the play best.
Given that use case, would you continue down the FoloCam + gimbal route and expect the basketball tracking/panning to continue improving, or do you think a two-camera fixed setup would ultimately be more reliable for high-volume highlight capture?
Would love to hear how you’d approach it.
Thanks!
Carter
I’ve been building an AI tracker for FoloCam for a while. This AI tracker will not only make the movements much smoother, but also eliminate distractions caused by multiple courts or courtside activities.
It should be available for testing in about a month. I’ll PM you the details.
Thanks! How do I access PMs here?
Just sent you a PM. If you click the 3 line icon on the top right corner you’ll see all your messages.
Would you mind sending to me as well? I’m usually filming in a multi court facility so access to that would be awesome
I am very interested in following this topic as I run a basketball academy here in Belgium. :blush:
