Thanks for the trial code and for the quick reply. I have others questions.
When I connect the Gimble and disconnect the tracker it display P and Y what they means ?
The system recognize automatically the basket court?
I’m trying to stream with FB with the URL provided: rtmps://live-api-s.facebook.com:443/rtmp/”stremkey” but the system didn’t connect, tried with Fiber connection and 5G. What can I control ?
I found this pagehttps://www.facebook.com/business/help/162540111070395?id=1123223941353904 and I saw that on the app FoloCam there is only 4k resolution, I can change only the frame rate. Can my problem related to this ?
P and Y mean Pitch and Yaw, and they are the pan/tilt angles in degrees. If you see P/Y values then the gimbal is connected.
No, FoloCam doesn’t recognize the court.
Live streaming supports only rtmp://, not rtmps://, so it currently doesn’t work with Facebook Live. I recommend using YouTube for live streaming instead.
For YouTube I need 50 people in my channel, I only want to transmit basketball game of my sons for parents that cannot join in the court.
I will wait, hope that you can do it.
I will try the recorder, I will have to center the iPhone in the middle, choose the game type and start recorder, that’s it? The system will follow the ball?
You need 50 subscribers only if you want to use the YouTube app to live stream. If you use the RTMP protocol then there is no subscriber requirement.
Basically yes. In fact the system will follow the ball even before you start recording. Please go through the User Guide before you start the first recording: FoloCam User Guide
I tried to run a live from YouTube and it works fine (not with Gilmble connected), this evening I will try to make a real test.
It could be usefull to have an option to activate/deactivate with a click the ball tracker if I need to change the camera angle to temporarily film the audience to continue live streaming, do you think that it’s feasible ?
Hello, I made a test and it not works works as expected. Many times the gimbal rotate without end. Need to stop it manually. Do you know why? I use Osmo mobile 8.
I didn’t follow up with them because they had stopped responding, so I don’t know whether they fixed the bug. However, as I mentioned in other threads, I implemented a workaround, so the bug should no longer affect us. Could you describe the exact symptoms you’re seeing to help me determine whether your issue is related to that bug?
