Indoor Dome Soccer
Hi,
I just bought the Folocam kit and we are about to begin our indoor dome soccer season. Has anyone filmed in a full field dome? Any tips on tripod height and settings?
Thanks in advance.
I record hockey, so same sorta low light situation. Never really had an issue there. I can’t speak for soccer…. but in general, be ready for some “trial and error” for the first few games. First game out, just set it up and record. See what comes of it. See what works or didn’t. Next game out try cycling through different configurations. every 15-20 min try a new set up. 10 feet hight, 14 feet high. Right on the sideline. maybe back 10 -15 feet from sideline. Obviously you want to be at the centre of the field.
For hockey I’m up roughly 11-13 feet. When I’m right on the boards there’s a bit of a blinspot right underneath as players come up the sides and tracking lags a bit. I might try going back a bit further.
That’s good advice. I was concerned with lighting and also that I wouldn’t have a lot of space given the dome curves overhead. I’ll use my other device as backup so I can try this out. Thanks!
Hi everyone,
I’m the social media manager for an 11-a-side soccer club, and I also handle content for the club’s futsal team.
We currently use the VEO system for our 11-a-side team, but I’ve been looking for something more straightforward and efficient to create content for both our outdoor soccer and futsal teams.
I came across your solution and decided to join the discussion because I started using FoloCam yesterday after purchasing a subscription. I already own an Insta360 Flow 2 Pro gimbal, so I was particularly interested in giving it a try.
Here’s the setup I used:
  • Gimbal: Insta360 Flow 2 Pro
  • Tripod: Manfrotto
  • Phone: iPhone 15 Pro Max
  • Camera position: High up in the stands, directly overlooking the center of the court
  • Tracking mode: Soccer PRO
  • Zoom: Fixed 1x
  • Recording settings: 4K at 30 fps
  • Lighting: Good indoor lighting conditions
My experience was a bit of a mixed bag.
There were definitely some positive aspects, but I noticed that the system frequently struggled to keep up with the action.
Futsal is a very fast-paced sport, much like hockey, with quick transitions and sudden changes of direction.
One issue I noticed was that whenever an attacking play ended with a shot on goal, the camera would often fail to follow the ball. Instead, it would stay focused on the player who took the shot. As that player started running back toward his own half, the camera would follow him, completely missing the opposing team’s counterattack.
I also found the gimbal movements to be particularly abrupt. Both the panning and the stopping felt quite jerky, with little to no smooth deceleration. In some cases, the sudden stops were so aggressive that they actually caused the gimbal itself to vibrate.
Overall, I think the concept behind FoloCam is really interesting and has a lot of potential. However, based on my initial experience, I feel the system still needs some work before it’s truly ready for the fast-paced nature of futsal.
I’m currently downloading the recorded footage, and I’d be more than happy to share it with your team. I hope my feedback and the actual recording can help you identify these issues and continue improving the app.
I’d really like to see this solution succeed, as I believe it could become a great tool for clubs like ours!
Thanks for sharing your experience. I plan to run some tests next week at practice. Of particular interest is auto-zoom. I read from other posts that it should be 2x to focus on the ball but, in a dome, I barely have 3’ from the sideline so if the action gets close, I think it would be zoomed in too much.
I’ll share the footage from all three 25-minute periods tonight so you can see how the recording turned out.
The zoom level should be based on the size of the field: 2x for a standard full-size field, 1.5x for a half-size field, and 1x for a quarter-size field. Unless your indoor dome has a full-size field, 2x would be too much zoom.
it’s a full size field but there’s virtually no room on the sidelines so I’m afraid if the play is on the side of the camera that it’d be zoomed in too much. Hence my interest in auto-zoom.
As promised, I’m sharing the three recordings I made during the match. I think this footage could also be helpful for the developers to better understand the fast-paced nature and dynamics of futsal, and hopefully use these insights to improve the overall recording experience.
@ferro780 The first two videos are much smoother than the third. I think there is something wrong with the third one. Do you still have the .srt and .log files (in the Files app under the FoloCam folder)? If you can send me those files I’ll take a look.
I’m sorry, but I’ve already deleted all the files from my phone because I’m running low on storage space.
Tomorrow is our first league game of the season, and I’ll try recording the match again. Afterward, I’ll see if I can upload the videos and share the logs with you as well, so you can take a closer look and investigate any issues.
@gchen I recorded the second match and sent you a private message with the videos and logs. Let me know what you think!
I recorded our practice scrimmage tonight so some feedback (similar to others).
  1. Very good at tracking the ball in play. We had balls scattered around the pitch and it didn’t get distracted by them.
  2. Using iPhone 16 Pro Max. Battery drained 30% in an hour. Screen stayed lit the entire time. Dimming it would help with battery life and prevent phone from getting too hot.
  3. Gimbal follows even when not recording. I was trying to test various settings and it kept moving. Perhaps disable tracking when not recording and certainly when settings window is open.
  4. Using Folocam kit gimbal (Comitok), phone seems slanted on the tripod. Add digital leveler so we can adjust tripod.
  5. On a 1/4 field for practice so I used 1x with auto-zoom. It doesn’t seem to zoom when play gets to the far corners.
  6. Tracking a bit jerky at times
  7. Focus went back to centre field after a missed shot instead of staying on the goalkeeper for goal kick. Missed a bit of the play.
  8. Cannot connect to another iPhone when remote control is active. I suspect they’re both using Bluetooth so it’s one or the other. When you hit broadcast, it shows the other device but when you click Connect, the device disappears. It worked when I turned off the remote control. Remote video is very clear!
  9. On 2nd iPhone, the controls disappear when not in use. The up arrow is somewhat lost to the white banner. The control arrows are at the edges of screen and it may be better together like a joystick.
  10. The 2nd iPhone suddenly disconnected. Not sure if I was too far for stable connection. I couldn’t reconnect. I suspect there’s a popup on the recording phone but it’s up on a tripod. Enable memory of the last phone connected to it and re-establish connection without having to prompt. It doesn’t make sense to have to bring down the camera to press the approve button.
Again, very impressed with it so far. Look forward to seeing further feature updates.
Hi FLY!
Could you explain how connecting a second iPhone works? I currently use my iPhone 15 Pro Max for recording, and I also have an iPhone 11 available.
I’d like to understand how I could use the iPhone 11 to remotely control the iPhone mounted on the gimbal.
Next Monday, I’ll be recording our second league match, and I’ll use 30 fps as @gchen recommended. Hopefully, this will help improve some of the issues I’ve previously reported. We’ll see how it goes!
My next test will be recording a youth 11-a-side soccer match, since our club has both traditional soccer and futsal teams. I’m curious to see how FoloCam performs on a full-size soccer field compared to a futsal court.
The user guide says iPhone 13 or higher is recommended so I hope you can download the app on your iPhone 11. Assuming you can, here’s how to connect it.
  1. Open Folocam on your iPhone 15, swipe right. It will say “No Stream Video”. (Swiping the other way shows videos you have previously recorded.) On the top left it will show your device name (eg. IPhone1234). Swipe left to get back to main screen.
  2. Open Folocam on your iPhone 11, swipe right. Your device name should be different (eg iPhone5678)
  3. On iPhone 11 hit the broadcast icon on the top right, a popup window will appear and show the other device (eg iphone1234) with a Connect button. Press Connect.
  4. On iPhone 15, a popup will appear for you to approve connection
  5. You should now see on your iPhone 11 what the iPhone 15 sees.
I hope this helps
I recorded our first game last night – full field dome.
Setup:
  • Folocam kit (Comitok)
  • iPhone 16 Pro Max
  • Neweer 13’ tripod
  • middle of the field, 4ft back from sidelines
  • 40k30fps 2x auto-zoom
  • Version 1.6.6 Beta
Observations:
  • Similar to previous feedback, it started moving as the players were getting onto the field. I had to reset it to the middle several times. It continued to pan and missed the kickoff. Suggestion: If I hit the buttons to reset to middle, look for the ball at the centre. As well, have a way to start / stop tracking.
  • Several shots at net missed; gimbal moved to the centre of the field and missed goal kick
  • Auto-zoom (experimental) went crazy a few times, going in and out very quickly
  • 2x zoom is too much when play is near the tripod; auto-zoom doesn’t zoom out enough. Missed a few moments when ball moved from one side to the other right in front of the tripod.
  • 4k30fps is nice but gets blurry if actions is fast while gimbal is also moving. 4k60fps was much better at this. Suggestion: add 4k60fps to all options, not just 1x.
  • 40% battery drain after 60 mins match (shortened for indoor). I turned brightness all the way down. Suggestion: auto-dim.
  • I levelled it using the Camera app and then switched to folocam.
I didn’t think 4k30fps tracked significantly better than 4k60fps. I’m going to test full game at 4k60fps next, even if I’m forced to stay at 1x.
Overall, it captured about 95% of the action and what it missed wasn’t important. Feedback from the other parents on the team has been positive.
Kudos to @gchen
Thanks to @Skyrex for helping me figure out how to use an iPad as the secondary device. I have now tested this further.
  1. Contrary to my earlier statement, I can connect both the iPad and remote control at the same time
  2. Using the iPad (same for iPhone) to move focus is very jerky. You have to tap the arrow and it moves a bit on each tap. Using the remote is smoother as you can hold onto the joystick.
  3. The “return to centre” button acts differently. The remote will go back to the gimbals physical centre whereas the app seems a bit off-centre – perhaps it’s where it thinks is the centre based on the midfield line. With the remote, the gimbal green light turns off for a split second while on the app, it stays lit and stops panning for about 5 seconds.
I will use the app to centre the gimbal before kickoff. Great that I don’t have to look up at the gimbal to see what it’s recording.
As mentioned before, would be great to be able to see the phones battery % from the iPad. Please prioritize that feature. Thanks!
Good morning,
I’ve recorded another futsal match using the app.
Recording settings:
  • Device: iPhone 15 Pro Max
  • Sport Mode: Soccer Pro
  • Zoom: 1x Fixed
  • Virtual Sideline: Off
  • Auto Tilt: On
  • Resolution: 4K 30 fps
My overall impression is that the camera’s tracking speed has improved (probably switching down to 30 fps has helped).
However, I’ve noticed that when the ball is stationary (during kick-offs or free kicks), the camera constantly tends to move, almost as if it doesn’t recognize that the ball is not moving. This creates an annoying effect of continuous, unnecessary camera movement.
In some parts of the video (during timeouts or before the start of the first or second half), I had to manually press the gimbal button to lock it in place and then reactivate it when the match resumed. Otherwise, the camera would have kept moving continuously.
I’ve also noticed that sometimes the camera tends to follow a player instead of keeping its focus on the ball (see 5:50 in the video).
The camera movements are still somewhat jerky and twitchy. In my opinion, they should be smoother and more fluid. I’m not sure whether this is something I need to adjust in the Insta360 app or directly in FoloCam, but at the moment, the tracking still feels quite “nervous” and could definitely benefit from smoother transitions.
A single futsal match generates approximately 10–11 GB of data. It would be great to have the option to record directly to an external SSD, avoiding filling up the phone’s internal storage.
Below, you can watch the edited recording that I’ve uploaded to YouTube.
I recorded another full field soccer match with the following changes:
  1. Curved Dome - so I had to drop tripod height to about 2.5m
  2. Sideline distance 1m — very little space
  3. 4k60fps 1x fixed
  4. iPad connected to see what its focused on
  5. Turned off cellular to conserve battery and reduce notifications
Observations / Results:
  1. 4k60fps started at 60fps but dropped down to 46fps for most of the game and became jerky; I had to use Davinci Resolve to smooth out the video. Perhaps streaming to iPad caused this??
  2. As before and what @ferro780 said , it keeps “seeking” before the kickoff and followed players running to position and I had to hit reset for it to focus on the ball
  3. As before, it pans to the centre when it’s a goal kick
  4. It did a full 360 spin even though I had sidelines enabled
  5. It stopped tracking altogether (I had to take it down and turn the gimbal off and on); phone kept recording, which is good
  6. Based on logs, it keep complaining that LicenseManager couldn’t connect to internet since I disabled cellular; battery usage is still about 40% in an hour
Next experiment:
  1. Go back to 4k30fps but 1x fixed (had used 2x before and it did some weird zooming in and out)
  2. Turn back on cellular (battery usage didn’t change much)
  3. Continue to stream to ipad
  4. Home field, which is a building instead of dome so back to 4m height and 2m from sidelines
@gchen I’ll DM you my files since I can’t share video publicly for privacy
@Fly @ferro780 The log files show that both of your gimbals were disconnected for extended periods of time. Since you’re using different brands of gimbals, I wonder if this could be an issue with DockKit.
@Fly You should definitely try 2Ă— zoom when filming a full field. At 1Ă—, the ball is too small to be detected consistently.
