Indoor Dome Soccer
Check to see if your gimbal has different follow modes.
With the Insta360 Flow 2 Pro the PF Pan Follow mode in “Active” mode works well for me and seemed smoother compared to the “Auto” mode which was more jerky at times.
But yes I agree the smaller micro pan movements aren’t ideal but zooming out using 1x if possible helps with that,
@gchen i didn’t like the weird zooming in and out (like a heartbeat) from 2x last time. I’ll try keeping it at 1x and drop back down to 4k30fps for the next game to see. Or even 1.5x I still prefer to have the iPad showing what it’s focused on so I’ll try everything else before stop using it, if that’s what’s causing the disconnection issue. I didn’t have the iPad when it recorded the first game without issues.
@yupkime I’ll using the kit and it defaults to PF.
@gchen do the logs show why fps dropped to 46? I’d like to keep it at 60 if possible. CPU utilization was at about 75% previously. It was just below 70 so I didn’t think that would be an issue.
@gchen I believe the gimbal disconnections happened before the start of the match (when you can see the teams entering the court), between the first and second halves, and during timeouts.
By pressing the dedicated button on the gimbal, I can lock it in place, which automatically disconnects it. When I press the button again, it reconnects.
I do this to prevent the camera from constantly moving up and down during breaks in the game.
@ferro780 I just tried it on the Comitok gimbal and it also works! I’ll be doing that going forward and put the gimbal in standby mode so it remains focused on the ball before kickoff. Thanks for that tip!
Yes I do the same thing for hockey in between periods but also I start a new video file at the same time for each period.
It’s great that the reconnection is virtually instant.
That’s a good point. It may improve performance if it doesn’t need to cache the entire match into memory.
I recorded another game last night and it didn’t go well – the only change I made was 4k30fps 1.5x auto.
Issues:
  1. Camera does some weird moves, distorts video
  2. Unable to follow ball - pans back and forth
  3. Gimbal stopped responding about 40 mins into the game; had to take it down and restart it several times. Gimbal was still showing green ring.
Landed on the following going forward:
  1. 4k30fps 2x auto – I think the weird moves was because it couldn’t find the ball when the play is further away as we’re playing full field. Footage was much better the first game when I had this setting, even though it did some weird zoom in and out repeatedly. Gimbal also did not stop in this setting.
  2. iPad to watch what it sees – I also didn’t use ipad the first game when it recorded fine. If setting it back to 2x auto zoom still freezes then I’ll forego the ipad and see.
  3. Disengage gimbal before kickoff – worked really well to stop it from panning before kickoff. It kicks in right away once I engage the gimbal.
  4. Stop recording after first half and record new video at 2nd half – great for editing
Basically what everyone here suggested! Thank you all! :slight_smile:
