Insta360 flow pro vs Comitok mogo
Is there any difference between insta360 flow pro gimbals and comitok one? Which gimbal is better for FoloCam?
The Insta360 Flow Pro is more popular, but I’d recommend the Comitok MOGO mainly because of its price. Functionally, they’re very similar.
I’ve been working closely with the Comitok team, so there may be additional optimizations specifically for the MOGO in the future.
Nice. Good to hear. I bought the Comitok one.
What mode should the Comitok be in for the app to work well? My initial test wasn’t as successful as I had hoped. I am using an iPhone 14 Pro Max and tried the soccer plus model at 3x. My gimbal defaults to HF when I turn it on it seems.
The gimbal model doesn’t matter when you place the gimbal on a tripod. What size is the field you filmed? The 3x zoom might be too sensitive. It is best for recording full-size fields from a stadium seat.
I can’t find the Comitok Mogo model where I am. Do you think this model ( Comitok L7C Pro) will work properly with Folocam?
No. FoloCam controls the gimbal via the DockKit protocol, so if a gimbal doesn’t explicitly mention DocKit support, then it can’t be used with FoloCam.
So, in addition to the gimbals on your list, other gimbals that include a DockKit will also work with Folocam. Did I understand that correctly?
For example, DJI’s new Osmo 8P gimbal.
Is the gimbal that comes in the kit the same as Comitok? If not, which would be the best option?
Yes, any DockKit gimbal should work with FoloCam, but DJI Osmo 8P is the only one that I haven’t tested myself.
Yes, it is. The Comitok Mogo is now on sale on Amazon for only $45.99 (the one with the remote).
