Kids Ice Hockey Video Samples > Insta360 Flow 2 Pro + iPhone 17
Unfortunately autozoom is not available using pro hockey mode.
Haven’t tried soccer mode with autozoom but won’t hurt to try for a period maybe?
Does it zoom either 1x or 1.5x but not in-between like 1.25x?
Depending on the arena 1.25x actually might be a good sweet spot if the setup if in the stands slightly elevated.
In trying to capture the near side action better I tilted and angled the gimbal just slightly forward about 5-10 degrees for a more top down view which I think probably caused the slight tilting on the far ends.
The tilt in the earlier videos was probably just bad tripod centering because it was at the maximum height because I was right close to the boards.
Not too concerned about it but more unhappy that it looks like the video quality went down post processing.
Feedback from parents has been all positive and other than the uploading and now post processing, the time commitment and effort is manageable.
Too many goals would be the biggest complaint if any. =)
Again the end goal for me is to be able to set it up once at the beginning and be confident it will capture 100% so I can sit and enjoy the game with the other parents.
Coaches can also review and see if any adjustments need to be made and of course the kids like to see themselves contribute to team success.
Unfortunately the other team player in the above highlights who put the last final goal into his own net probably won’t want to see that replay but it was great to have this video so we could figure out what exactly happened there.
I’m not sure if zoom locks in at something in between 1.5x and 1.0x or if it was gradually moving between the two. The zooming footage was very smooth.
Let me know if you try Soccer PRO for a period. Maybe I’ll try it for a period like 3rd when they flood after 2…. Looks like the next 2 weeks I’ll be filming manually.
Nov 7th weekend we are in Rochester for a tournament so there will likely be arenas that I need FoloCam. Maybe I’ll try Soccer PRO for a period then…
I tried soccer mode recently for ice hockey and there wasn’t a discernable difference from what I can tell in terms of tracking.
I was trying to see if it would auto zoom in and out but I think I need to fiddle around with it more and possibly use a wider shot from farther out to see that work.
Here is a new video showing a setup right along the side at ice level with the camera actually hanging over the edge. It was a faster adult skate but turned out well.
Tracking was decent but the main concern is how it would lose focus tracking players getting off and on the bench right beside the camera which happened often.
Being able to set an absolute maximum x-axis left and right restriction I think is the only way to prevent this from happening especially when the camera position is not centered at the exact middle like in this case.
For optimal viewing that doesn’t require any post processing for hockey I am starting to settle on using the following settings if able to setup in the seats about 3-10 rows up:
Ice Hockey Pro
1.5x zoom 30fps (1x if closer right at ice level)
PF Pan Follow Gimbal mode - Active Plus Mode
Fixed tilt - Usually between 10-15 degrees to cover ice surface
Virtual Sideline - About 5-10 feet in front of actual rink edge
Tripod Height - No difference if using fixed tilt?
On the tripod I may tilt the gimbal slightly forward to give it a more top down vantage point if the view angle benefits from it.
Output is smooth and tracking is good enough that I don’t need to constantly monitor the play and can enjoy the game.
The only thing now is to have pen and paper ready to record time marks of highlights that I want to clip out later - Maybe that can be an added feature where a screen button can be configured minus ~5-10 seconds to place a video playback track mark or create a text time log for quick review later?
And will any tracking camera ever be good enough to track and see a long shot puck heading all the way into an empty net goal like at 25:25?
One more video showing a poor arena setup with glass in the way but at ice level with no empty space in front.
Tracking was very good and it worked relatively well able to keep up with the speed of play.
I would actually prefer this view point for recording and replaying game play if it were always possible with no obstructions in the way.
There was no players bench on this side so no loss of tracking because of that.
I think this should be the recommended setting.
Tripod Height still matters when Virtual Sideline is on. Did you see the yellow virtual sideline on the screen? If the tripod height isn’t accurate then the virtual sideline won’t align with the actual sideline, especially when the gimbal pans to the left or right.
I’ll check why it didn’t catch this shot.
Didn’t know that the tripod height setting is designed to work in conjunction with the virtual sideline.
My impression was that it was primarily connected to the auto tilt function which would adjust accordingly.
I do see the yellow virtual sideline for which I just adjust the number higher until it virtually appears where I want to set it which is above the actual physical sideline. But perhaps that is not allowing it to work properly then.
The VS distance number is not accurate if I do it that way but I will try to make it exact next time with the estimated tripod height above the playing surface and see if it affects the panning and off area player detection.
For that empty net goal, the tracking would have to specifically see and directly track the puck all the way down by itself and basically then disregard most of the players on the screen who give up on the play and slow down as soon as they see the puck going into the net. Feels difficult to program that in but it would also apply to icing plays when the puck is shot down the ice all the way.
That said for icing plays, tracking the puck isn’t vital as play will be stopped when it reaches the other end but for an empty net goal, it is always fun and exciting to see it go into the net but then ideally it has to pan back to watch the celebration …
I like the recommended settings however, my only concern is the fixed tilt setting. Since im not using folocam for the 20-30ft away from the surface and usually only 1-6ft away.
Without the auto tilt, being so close to the boards the gimbal needs to auto tilt back up, esp if you set it to aim downward. Though the middle tilt angle could be lowered a bit.
Yes if that close to the action then auto tilt would be needed to catch the action nearby.
When hockey has variable zoom available like it has for soccer then I will be more inclined to use auto tilt if it frames the play well enough to capture all the action without including all the extra arena seating above and below.
Using the virtual sideline option correctly with tripod height and distance numbers worked ok but the one thing that still bothers me is the overextension on both sides that includes all the seating.
I suppose the tracking is trying to center the action in the middle as much as possible but hopefully it will be able to eventually recognize and prioritize the playing surface to fill the screen as much as possible at all times especially when near the far ends.
The added benefit would be the reduction of micro panning movements when play is entirely in the zone for an extended period of time.
This would be the only significant problem when using the camera up in the stands and away from the sideline.
