Hi, I need some help setting up FoloCam with Insta360 Flow 2 Pro for a kids soccer game.
I’m trying to record an elementary school 5v5 soccer match using:
iPhone 15 Pro running iOS 26.2.1
Insta360 Flow 2 Pro, firmware v5.75.47
FoloCam, apparently the latest version because no App Store update is available
Soccer / Soccer Pro mode
Apple DockKit connection
The iPhone seems to be connected correctly. In Bluetooth settings, both “Flow 2 Pro” and “Flow 2 Pro Dock” are connected. In FoloCam, I can see the P/Y angle values, and the green status indicator appears, so I think the gimbal connection itself is working.
The Insta360 app says the Flow 2 Pro firmware is up to date.
My setup:
5v5 elementary school soccer match
Young kids, around U8/U9 level
Dirt/gravel field
Camera height: around 6.5 ft
Camera position: around 10 ft away from the sideline/touchline
Starting position is shown in the attached screenshots
I tried both Soccer and Soccer Pro
I tried different zoom levels: x1, x2, and x3
The ball was sometimes quite close and clearly visible near the center area of the screen
The problem:
Even when the ball is clearly visible, FoloCam does not seem to track the soccer ball at all.
Also, after double-clicking the button on the Flow 2 Pro to return to the initial position, when I single-click to start tracking, the gimbal sometimes tilts up toward the sky, sometimes tilts down toward the ground, and occasionally points in a reasonable direction, but still does not track the ball.
I’m not sure if this is a setup/orientation problem, a gimbal/DockKit issue, a software compatibility issue, or if I am misunderstanding how to start tracking.
I’m also wondering if the following conditions could be causing the issue:
The players are very young, so the ball movement is less predictable and there are many players around the ball
There are multiple soccer balls visible in the frame, especially near the sideline and benches
Another soccer game/practice is happening in the background
The field is a dirt/gravel field, so the ball may not stand out clearly enough
The camera may be too close to the sideline or not high enough
I was really looking forward to using FoloCam for my son’s games, so I’d really appreciate practical advice on how to make it work properly. I don’t need it to be perfect, but I would like to understand the correct setup and what conditions are required for stable ball tracking.
Could you please advise on the correct setup?
Specific questions:
Is the iPhone orientation correct for Flow 2 Pro + FoloCam? Should the bottom/charging port side of the iPhone face right in landscape mode?
Should the camera be aimed at the center of the field when Y = 0°?
Is 6.5 ft camera height enough for 5v5 kids soccer, or should it be higher?
Is being around 10 ft away from the touchline too close or too far for FoloCam?
Could multiple balls in the frame prevent FoloCam from locking onto the match ball?
Could another game/practice in the background interfere with ball detection?
Does FoloCam work well for younger kids’ soccer, such as U8/U9, where the play can be crowded and less structured?
Is there any specific setting required in Soccer Pro mode to make the ball tracking start?
Is there any visual indicator that confirms the ball has been detected or locked?
For iPhone 15 Pro, should I use x1, x2, or x3 zoom for this kind of small-sided kids soccer match?
Is there anything wrong with my starting position shown in the screenshots?
Are iOS 26.2.1 and Flow 2 Pro firmware v5.75.47 known to work properly with FoloCam soccer tracking, or could this be a compatibility issue?
I have attached screenshots of the camera view, Bluetooth connection, firmware version, and setup. Any advice would be appreciated.
If helpful, I can also upload a short screen recording showing the gimbal tilting toward the sky/ground and not tracking the ball.
